Can be displayed in the catalog profiles the size of the American profiles with units of measurement in mm, cm or m?
Solved by andrea_pontiggia. Go to Solution.
I'm not sure what you mean. If the quesiton is for the display in the section database browser then:
Otherwise I think you may use the Canadian CISC instead :
