Discussion Groups
Robot Structural Analysis
Distinguished Contributor
PatrickEC
Additional Parameters (CAN/CSA S16-09 Code) - Selection for sway or (...)
194 Views, 3 Replies
08-01-2012 08:19 AM
http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-5B1C7B9A-AD37-42F7-AF4A-A3BD4128FE1-972.htm
I cannot figure out what "Selection for sway or non-sway structure" is referring to.
Please use plain text.
PatrickEC
Re: Additional Parameters (CAN/CSA S16-09 Code) - Selection for sway or (...)
08-02-2012 07:11 AM in reply to: PatrickEC
I have received an email notification with Rafal's response in this thread, but it does not show up here.
Anyway, of course I know what a sway frame is. What I meant was that I do not see in this dialog the option listed in the description.
Product Support
Artur.Kosakowski
08-02-2012 07:32 AM in reply to: PatrickEC
Patrick,
This definition is available in the buckling parameters part (the exact location depends on the selected design code). The line about sway / non sway definition is visible in Help for additional parameters by mistake. I have asked to have it removed from there.
Artur Kosakowski
PatrickEC
08-02-2012 07:52 AM in reply to: Artur.Kosakowski
That is what I thought, but wanted to make sure that I was not missing something. Thanks!
