http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-5B1C7B9A-AD37-42F7-AF4A-A3BD4128FE1-972.htm
I cannot figure out what "Selection for sway or non-sway structure" is referring to.
Solved by Artur.Kosakowski. Go to Solution.
I have received an email notification with Rafal's response in this thread, but it does not show up here.
Anyway, of course I know what a sway frame is. What I meant was that I do not see in this dialog the option listed in the description.
Patrick,
This definition is available in the buckling parameters part (the exact location depends on the selected design code). The line about sway / non sway definition is visible in Help for additional parameters by mistake. I have asked to have it removed from there.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
That is what I thought, but wanted to make sure that I was not missing something. Thanks!
