Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Adding stiffeners to a fixed column base
1 REPLY 1
620 Views, 1 Reply
I have set up a fxed column base connection and would like to add stiffeners to the column and the base plate.  I understand there are options to add these stiffeners when defining the connection, however the stiffener layout and positioning that i require are not included in the within the inbuild stiffener types as shown below:
Is it possible to modify these already existing stiffener types or will i need to create my stiffeners from scratch.  If so, how would I go about doing this?  Also what kind of connection will be assigned to the stiffeners or will they simply be part of the original fixed column base connection?
Many thanks in advance.
1 REPLY 1
Artur.Kosakowski
You are not able to add any new stiffeners' scheme to the predefined ones. This is hard coded.
Artur Kosakowski
