Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
ADDING NODAL MASS FOR SEISMIC DESIGN
5 REPLIES 5
TSOFA
1287 Views, 5 Replies
Hi, again Smiley Happy
I have to design the foundation  that will support a container on a concrete table. In order to model the loads on the container (which I don't have to desing) like wind snow and seismic forces, I am going to apply the resultants on a node at the center of gravity of the container. Then I will connect this node with rigid liks to the points of the anchoring plates of the container and by this way I want to transfer the loads of the container to the concrete table that I have to design. I am not sure how I will model the weight of the container at the C.G. in order to be 'activated' from the seismic loading. I assume that the most easy way is to act a nodal force (kN) equal to the weight of the container, but I was wondering how I can use the 'nodal mass' forces.
5 REPLIES 5
Artur.Kosakowski
in reply to: TSOFA
In the same way Smiley Happy
Artur Kosakowski
TSOFA
in reply to: TSOFA
Sorry but I didn't get you... I tried to add a mass on a node (for example for LC1) and then to run the seismic loads for this LC (by adding this LC to load to mass conversion table) but the reactions of the seismic loading were not right. Like he could not see the added mass. Can you send me the steps that you are taking?
Artur.Kosakowski
in reply to: TSOFA
Artur Kosakowski
Dear
I've been adding Nodal Mass for some Node, and then Load to Mass conversion. As below
However, the result of seismic load is nothings change between before adding Nodal mass and after adding Nodal Mass
Anyone can help me
You need to either define added masses in the static seismic case(s) or define loads and convert them into masses. You cannot convert added masses into masses Smiley Wink
Artur Kosakowski
