Discussion Groups
Robot Structural Analysis
Active Member
joaocosmoscivil
Adding a different thickness to part of a slab
830 Views, 12 Replies
08-11-2012 02:43 AM
Consider the slab on the image, 250mm thick.
I need to make the gray area on the right thicker, 500mm. Is there a way to "divide" the slab into two?
I tried the "divide" tool but it doesn't work on slabs in Robot 2012. I then created the slab in gray to the right, on top of the original red one. But then there's another problem: is it possible to trim the red slab somehow? The "trim" tool also seems not to do the job.
I'm trying not to have to remodel the slab from scratch and re-apply all the loads.
Thanks in advance
Joao
Please use plain text.
Valued Mentor
tony.ridley
Re: Adding a different thickness to part of a slab
08-12-2012 10:45 PM in reply to: joaocosmoscivil
For the slab highlighted in red there are 3 options.
  1. Redraw it
  2. After slecting it (and it goes red) hover the mouse on one of the edges you want to move, the edge will go blue.  Then click this edge and you will be able to drag it to the new location (at the edge of the grey panel).
  3. Click on contour definition in the object inspector and manually edit the coordinates of the edge to be changed.
Tony
Product Support
Artur.Kosakowski
08-12-2012 11:57 PM in reply to: joaocosmoscivil
If you create a smaller panel inside a larger one the properties assigned to the smaller one will be assigned to surface elements generated there. There is no need to trim the red panel (the overlapped part of the larger panel will not be 'double' meshed).
For the loads: you have to add smaller panel number (list of elements column in the loads table) to already defined surface loads or define them in the way shown below:
Artur Kosakowski
Valued Mentor
tony.ridley
08-13-2012 12:04 AM in reply to: Artur.Kosakowski
Artur,
You won't get the "overlapping panels" error with this method?
Tony
Product Support
Artur.Kosakowski
08-13-2012 12:38 AM in reply to: tony.ridley
No, you will not. This is a panel within a panel rather than a part of the panel over a part of a panel :smileyhappy:
This 'cuts off' a part of a larger panel - in the same way you create openings (then it is just an inner contour with no new thickness assigned).
Artur Kosakowski
Active Member
joaocosmoscivil
08-18-2012 01:10 AM in reply to: tony.ridley
The problem with this slab particularly is that it's made of lines and curves. By selecting an edge or node, it will drag the adjacent elements - if they're a curve, it will grow really big.
Probably the best way is to redraw it node by node with lines, two separate slabs. The problem with having one slab on top of the other is that the columns below would be connected to both slabs. That means that the node rigidity would not be calculated right, unless both the slabs would have the same equivalent moment of inertia as one 500mm slab, which is very unlikely!
Just wanted to know if there was a way to divide the slab into two, like you can do with the bars. But it seems there isnt.
Thanks for the reply though.
Joao
Product Support
Artur.Kosakowski
08-19-2012 11:52 PM in reply to: joaocosmoscivil
1. Draw a line at the border of the thinner and the thicker parts
2. Mesh the panel as it is
3. Open the panel definition dialog and define the thicker/thinner part based on the selection of surface elements from either side of the line
Artur Kosakowski
Distinguished Contributor
mirko.jurcevic
09-25-2013 01:59 AM in reply to: Artur.Kosakowski
O   M   G !!
The whole morning I've been trying to do a simple task like that and I can't do it.  :smileyfrustrated:
I want to change some part of slab to be 45cm thick (rest of the slab is 20cm thick), but there is no way to do it.
Why is panel manipulation so complicated?!
I am going to try that FE thing, but I am not optimistic..
INTELIKA
Mirko Jurcevic M.Eng.
INTELIKA d.o.o.
www.intelika.hr
Product Support
Rafal.Gaweda
09-25-2013 02:36 AM in reply to: mirko.jurcevic
This way http://screencast.com/t/sTCYALMgO maybe?
Rafal Gaweda
mirko.jurcevic
09-25-2013 02:53 AM in reply to: Rafal.Gaweda
I'm sorry, but that's just not working for me.  :smileysad:
I will send you link to my model and try to do that there.
INTELIKA
INTELIKA d.o.o.
www.intelika.hr
