Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
adding a beam midway of one edge of the contour
4 REPLIES 4
HoshangMustafa
310 Views, 4 Replies
Hi I drew a contour and applied surface load. Later I decided to add a beam midway of one edge of the contour. What is the easiest way to do it?
4 REPLIES 4
1. Define a bar along this edge
2. Divide it into 2 parts
3. Delete these bars leaving the middle node so that you have the origin node of the beam defined
Artur Kosakowski
or use snap
Rafal Gaweda
Hi
I meant when adding a beam into a contour area, does the contour divide into two parts, hence the surface load also?
My assumption is that your question is in fact: will the cladding load be transferred to the newly added beam?
Yes, the model generation will do this for you and no additional modification of the cladding is needed.
Artur Kosakowski
