Discussion Groups
Robot Structural Analysis
Valued Mentor
HoshangMustafa
adding a beam midway of one edge of the contour
129 Views, 4 Replies
02-01-2013 09:14 AM
Hi I drew a contour and applied surface load. Later I decided to add a beam midway of one edge of the contour. What is the easiest way to do it?
Please use plain text.
Product Support
Artur.Kosakowski
Re: adding a beam midway of one edge of the contour
02-04-2013 12:25 AM in reply to: HoshangMustafa
1. Define a bar along this edge
2. Divide it into 2 parts
3. Delete these bars leaving the middle node so that you have the origin node of the beam defined
Artur Kosakowski
Product Support
Rafal.Gaweda
02-04-2013 12:32 AM in reply to: Artur.Kosakowski
or use snap
Rafal Gaweda
Valued Mentor
HoshangMustafa
02-04-2013 02:26 AM in reply to: Artur.Kosakowski
Hi
I meant when adding a beam into a contour area, does the contour divide into two parts, hence the surface load also?
Product Support
Artur.Kosakowski
02-04-2013 02:33 AM in reply to: HoshangMustafa
My assumption is that your question is in fact: will the cladding load be transferred to the newly added beam?
Yes, the model generation will do this for you and no additional modification of the cladding is needed.
Artur Kosakowski
