Hi I drew a contour and applied surface load. Later I decided to add a beam midway of one edge of the contour. What is the easiest way to do it?
Solved by Artur.Kosakowski. Go to Solution.
1. Define a bar along this edge
2. Divide it into 2 parts
3. Delete these bars leaving the middle node so that you have the origin node of the beam defined
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Hi
I meant when adding a beam into a contour area, does the contour divide into two parts, hence the surface load also?
My assumption is that your question is in fact: will the cladding load be transferred to the newly added beam?
Yes, the model generation will do this for you and no additional modification of the cladding is needed.
