How does Robot store the addins that have been installed? Is it done with an XML or TXT file or something of the sort? I'd like to know if I can create a simple program to edit the file, to simplify the installation process for the end user. I've already looked in the installation folder and in %APPDATA%, but can't find anything.
Solved by Rafal.Gaweda. Go to Solution.
Addin file is stored in the location from which it is "attached" to menu
Adding to menu creates two registry keys based on addin GUID.
one in HKEY_CURRENT_USER\Software\Autodesk\Structural\RSA\MenuExtension
second in HKEY_CURRENT_USER\Software\Autodesk\Structural\RSA\AddIns
