Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Add permanent load to footfall and modal analysis
1 REPLY 1
305 Views, 1 Reply
The footfall and modal analysis only take the structures deadload into consideration. I want to add an extra permament load that the calulation should consider sinse heavy permanent equipment will be placed on the floor. Have tried to add extra permanent load without any change in the result.
Is it possible? How in that case?
Tags (3)
1 REPLY 1
Artur.Kosakowski
You should convert this load into dynamic mass
Artur Kosakowski
