Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Message 1 of 8
mjoflor
583 Views, 7 Replies
Add mass
How can i add mass a box or a rectangular of steel, for example, i mean i need the object had a mass defined. thanks
7 REPLIES 7
Message 2 of 8
Artur.Kosakowski
in reply to: mjoflor
I'm not sure if I understand - do you want to define a mass of a rectangular steel profile which is different than its self weight calculated based on its cross section area and assigned material?
Artur Kosakowski
Message 3 of 8
mjoflor
in reply to: Artur.Kosakowski
correct
Message 4 of 8
Artur.Kosakowski
As the self weight is calculated automatically based on these properties you need to exclude such bars from the list for self-weight and replace that load with the uniform bar load of the appropriate value. Otherwise you can create a 'special' material of density that corresponds to the difference in values and assign it to these bars.
Artur Kosakowski
Message 5 of 8
mjoflor
for example a steel container that it had a load of 2500 lbs ?????
Message 6 of 8
Artur.Kosakowski
I'm not sure if we are thinking about the same issue. Could you make a sketch of the situation please?
Artur Kosakowski
Message 7 of 8
mjoflor
The point is the structure is gone load by the conteiners each one had a load of 2500 lbs
Message 8 of 8
Artur.Kosakowski
You mat try to use the contour load on a cladding and then convert this load into mass if needed.
Artur Kosakowski
