In the calculation note of a reinforced concrete beam does not appear the diagrams of accidental actions.
it is possible to make them appear?
thanks
Solved by Artur.Kosakowski. Go to Solution.
Do you have any ALS combinations?
In my project I have ULS combinations of rules and combinations ALS (Seismic and explosion) of legislation, but in the calculation note shows the diagram of actions ULS.
The major actions, however, are the ALS.
That's for continuous footings rather than beams. The workaround for now is to add the corresponding screen capture from the diagrams tab to the note. The cause has to be investigated by the development team.
