Discussion Groups
Robot Structural Analysis
New Member
ashourw
Acceleration of building due to wind load
694 Views, 4 Replies
02-28-2012 03:11 AM
Hey there,
I have two questions which are related regarding above subject:
1) Does robot give acceleration of building due wind loa?
2) if yes does it requie nonlinear analysis?
Thank you all in advanc.
Please use plain text.
Product Support
Artur.Kosakowski
Re: Acceleration of building due to wind load
02-28-2012 03:23 AM in reply to: ashourw
The non linear analysis is not required but you need to define how load (wind) changes in time either using time history analysis or harmonic analysis (limited to one type of load change function). For the prior you can get acceleration in nodes directly whereas for the later it is necessary to calculate this value based on obtained displacements.
Artur Kosakowski
New Member
ashourw
02-29-2012 02:51 AM in reply to: ashourw
Thanks for your quick responsed but to make the picture more clear,
- If i want to define function to get the accel. "harmoinc function", does it required that the wind to be genarated from ROBOT or it can be done while i express the wind as a static uniform load on cladding ?
Best regards,
Product Support
Artur.Kosakowski
02-29-2012 02:56 AM in reply to: ashourw
The function is 'applied' to a load case (all loads defined within a load case regardless of their 'origin').
Artur Kosakowski
Valued Mentor
tony.ridley
02-29-2012 05:51 AM in reply to: Artur.Kosakowski
