Good Morning / Evening
I m wondering if there is a way to accelerate the loading of seismic diplacement on the stories tables.
i takes a lot of time with relative big models ...
thank you
Solved by Rafal.Gaweda. Go to Solution.
Hi Please find below the link ( Model without the _RT extension )
i was trying to use API to extract values of displacement DrUx, DrUy for all stories , it takes about 10 min ...
i was wondering if its normal for this size of model.
i was wondering also , if RSA does the calculation of these values before ( in order to display them instantly ) of after asking for them in the storie table.
Thank you
Sorry for delay
lets say that it takes much more time using API that RSA
what im using on my program is something like that :
Données_MSP_x_NIVEAUX(1).dr1 = Résultats_Etages.Displacements(1, Caractéristique_Séisme_X.numéro).DrUX
please make verification by your side.
Another questions please :
1. can I access to the displacements (or any other values) directly by using tables on RSA ?
2.How displacements of a storie are calculated ?
Thank you.
@faisal.aaouatif wrote:
Sorry for delay
Yes I know, It is being investigated
Do you mean opening table, saving to csv - possible by API to save to txt , not csv
example
http://docs.autodesk.com/RSAPRO/2014/ENU/filesROBOT/GUID-890C3B44-F7EE-4BB1-8C39-19F445B5B94E.htm
Hi
By Point 1 , I meant if there any possibility to get a given value on a table by affording row and a column number ( something like for the 5th ligne ( which match to a floor 5 ) , take the value of the 6 column ( which correpond to Drx .. )
Thank you
