Question :
Does the SDK application will be available in the RSA 2012x64 ? Because it didn't work for the 2011prox64. Can we expect new tutorials and more or additional examples in the manual ?
Solved by Rafal.Gaweda. Go to Solution.
take a look at message 20 (above)
folder : ....\x86\Tools\RSASDK
the link is broken "expired" more expecified, i cand downlioad thanks anyway
Are the files in these links, still available for download and would they be applicable for RSA 2014? Thanks.
This is silly. WHy isn't this SDK hosted somewhere on Autodesk's server so we can all download it without asking you for a new link every time? All of the links provided have expired. Care for a new one? LOL
Run the installation program of Autodesk Robot Structural Analysis (generally, you’ll find a “setup.exe” in
C:\Autodesk\ Autodesk_Robot_Structural_Analysis_Professional_2015_Multilingual_Win_64bit).
Click “Install Tools & utilities” button.
Check “Autodesk Robot Structural Analysis Professional SDK” and click install.
Once installed you’ll find help and tutorial in :
Start/Programs/Autodesk/ Autodesk Robot Structural Analysis Professional 2015/SDK
or
install SDK directly from media : \x64\Tools\RSASDK\RSA_SDK.msi
and the path C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2015\SDK\ to whole SDK, documentation, tutorial
