Hello everybody……
I tried to find a solution for my question in the topics, but I didn’t find anything.
My question is about combining the loads. I have several groups of loads:
Dead – G1 (1);
Live – Q1 (2);
- Q2 (3);
Wind – W1 (4);
- W2 (5);
Snow – S1 (6);
I prefer to use automatic code combinations. So how to tell the program do not aloud simultaneous acting in generated code combinations of these loads: (3) with (4), (3) with (5), (4) with (5), and (3) with (6).
I will be very grateful if someone explains the method step by step.
Thank you very much.
Solved by Rafal.Gaweda. Go to Solution.
Create new subnatures of LIVE loads for wind and snow, define these W and S cases using them, set correct relations for automatic code combination generation
Thank you for your answer.
I tried to do this by myself, but unfortunately I couldn't understand the logics of the operations of the program. So please, can you explain the process in details.
Thank you again......
....If I change the NATURE of the wind and snow loads - in generated cobinatins they will get wrong coefficient ψ depending on their nature.....
I'm sorry, but this is stupid.......This option is a basic requirement for using the software......
