Hi all,
I work in an engineering office where Autodesk products are not well known. Lately the senior engineer suggested moving to Autodesk products. In order to do that, Architectures are using Revit architecture and structural engineers will have the responsibility to make analytical models. After making analytical model the model is moved to Robot so we can analyze and design members. After finishing the design of each member we will update the model in Revit.
The procedure written above was done.
Every time we updated the model this message appears: “Rebar is placed completely outside of its host”. I tried it many time in different examples and the problem still happening.
I hope you can help me.
It's basically to do with the way that your beam family is set up in Revit. See in this picture the blue line is defined outside the shape (user defined beam family).
Compare with a beam exported from Robot, the sweep line is at the centroid.
This is why the reo is going outside the beam, as the reference line is in the wrong place.
Tony
Thank you for your help 🙂
|Infact what i am talking about differs somehow; not only reinforcemnt is not within the host, Indeed reinforcemnt lies in places where beams are not existing. You can figure what i am talking about by looking to the attached picture.
Waiting to hear from you,
Kindly find the attached simple 3D model for a frame system (columns and beams- No slabs). This problem is general; simple model or any other complex projects I work on have the same problem. the attached model can be analyzed on robot under self weight only since I did not define any load to the frame system. when trying to export this model to robot and backward to Revit the same problem previously explained happened.
Dear Rafal,
I sent You the model that I talk about yesterday. Hopefully you can discover the problem so I can make a progress in the workflow between Revit and Robot.
Thank YOU 🙂
This situation for multispan beams
Bug...
Workaround: design spans separately (one span beams) or delete wrong reinforcement in case of multispan beams designed in Robot in Revit
Dear Rafal,
While I am exploring videos about the integration between Revit and Robot I found this one:
http://www.youtube.com/watch?v=8TD4ZSWBqjs
In this video and exactly at 3:00, I found that beams reinforcement were exported from Robot to Revit and the results seem to be correct; i.e. reinforcement lies on their host beams. The Video did not mentioned anything about bugs and what I conclude that it is possible to have the integration between Revit and Robot without any problem.
MY QUESTION: Is the bug You mentioned is related to 2014 version? or the bug is general for any edition of Revit? If the answer is that the bug is general and not only for 2014 version so how the tutorial contain clean results?
Thank You
Note: Attached to my reply a .jpg picture from the mentioned video
Dear All
I have same problem, Pl see my image below
Pl help me to fix this problem
Thanks all
rafal gwada, on many ocassion u av bailed me out on the use of robot, even though u dont know me, please man give us a solutuion on this problem of bars been placed completely outside its host when transferring reinforment from robot to revit....its a big let down
@Rafal.Gaweda wrote:I happens also in 2013 version
Anyone has found an answer?
The problem still occurs in 2018 version
same problem here, its disturbing and it wont the serve the process that it reduces the labour of drafting
From what I've found is that geometry is different in Revit than in Robot.
Because if you model lets say a beam that is cast-in-place on top of a slab. The beam doesn't really have any "real" supports with a specific width.
And when you run the calculations in Robot, you have to define a support width for the anchorage to be possible. This means that your theoretical length is now changed and not exactly what it is in Revit. So when your calculations are done and you are ready to send it back to Revit, remember that your calculations is done on a beam that is lets say 400mm longer than the actual beam in Revit. Since there seem to be no connection or logical connection between changes, the beam is exported faulty and Revit has forgotten it's location.
But however, if you design a simply supported beam in Revit, you have to make sure that your cut-length in Revit must be the same as the span length in Robot.
To conclude everything. There seems to be no idea to analyze and calculate a whole beam-column system in a building if you do not know exactly the width of all supports etc and make it thorough. Otherwise it will be placed outside its' host.
