Discussion Groups
Robot Structural Analysis
Distinguished Contributor
O.Maille
3D FE analysis of bespoke steel connection
972 Views, 5 Replies
09-10-2012 10:53 AM
I need to design a bolted flange to flange connection for a railway beam.
I can model the beams and bolts in Acad, 3ds max, blender etc....
I have the infrastructural and building design suites.
Can I import 3D solids into robot?
if not I can created surfaces and mesh solids...what is the best way?
Please use plain text.
Product Support
Rafal.Gaweda
Re: 3D FE analysis of bespoke steel connection
09-11-2012 03:33 AM in reply to: O.Maille
Yes , as Solids. IN case of your file just convert surfaces to solids.
Yes, this way:
- save solids from ACAD,..., as ACIS solids -> *.sat file
- start Robot with Volumetric structure type
- enable ACIS (see below)
- set proper unit (in case of this file mm)
- open sat file
Two other approaches:
1. Model it from scratch in Robot as solids
2. Simplify model (as shell) creating each beam from 3 panels (web + 2 flanges), bolts as ordinary bars
Rafal Gaweda
Valued Contributor
TraitCarré
03-01-2013 03:24 AM in reply to: Rafal.Gaweda
I'm trying to import a .sat file (see below), doesn't work, the Solid Modeler options are not available.
thanks
sat file : https://dl.dropbox.com/u/79282449/passerelle.zip
Benoît
Product Support
Rafal.Gaweda
03-01-2013 04:46 AM in reply to: TraitCarré
I am unable to open this file neither in Robot nor in Revit  nor in ACAD.
Rafal Gaweda
Valued Contributor
TraitCarré
03-03-2013 08:44 PM in reply to: Rafal.Gaweda
the .sat file was created under Cadwork.
Please have a look on the pdf, maybe I have to choose another ACIS version (21.0, 20.2, ...)?
thanks
Benoît
Product Support
Rafal.Gaweda
03-03-2013 11:47 PM in reply to: TraitCarré
It is not possible to select ACIS version in ACAD, RST, Robot.
Try to save sat file in ACIS 13 or 14 or....  format them try to open in our soft.
Rafal Gaweda
