Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
2nd order modal analysis
4 REPLIES 4
aruser
345 Views, 4 Replies
Is there a way to perform a "2nd order modal analysis"?
I am doing a calibration with other softwares and the conclusion we have reached is due to the type of modal analysis robot do.
4 REPLIES 4
Rafal.Gaweda
in reply to: aruser
aruser
in reply to: Rafal.Gaweda
Hi Rafal,
Sorry but I don't get any clear idea.
Rafal.Gaweda
in reply to: aruser
My idea was to show you how modal modal analysis on nonlinear model is performed, what assumptions are, what limitations are.
Rafal Gaweda
Pawel.Pulak
in reply to: aruser
your request was not quite clear so Rafal answered assuming dynamic analysis run for the non-linear models.
If you mean the "stress stiffening" effects in modal analysis (like increasing the frequency of vibrations in case of big centrifugal forces or decreasing the frequency of vibrations in case of high-rise structures with big compression forces in columns and cores) it can be considered in Robot using modal analysis taking into account static forces.
Some screen capture showing how to activate it is available there.
If this post answers your question please click the "Accept as Solution" button. It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
