According to ACI code I want to analyze a simple building which is not frame
It's a simple beam column structure I mean that the joint between beam and column isn't fixed
and the column was poured seperatelly from the slab and the beam but you know the steel of the column and beams interlaps so I don't think I is Fully roller or pin as a support
please tell me how to simulate the column support from your previous Knowledge
