2.4.1.4 Partial factors for materials in RSA
9 REPLIES 9
Message 1 of 10
1304 Views, 9 Replies
Dear RSA support and advanced users,
Im doing RC column calculation for one ongoing project at the moment.
1) I can not verify results before i will see how Robot takes safety factor for materials such as Concrete/reinforcement steel.
Calculations are done acc. EC-2 norms. Please see shotcut attached from Eurocode how it shall be taken for calculation.
2) Acc. to EC-2 to the column applied "initial bow imperfection" which is M=Nc*lc/x. x<=400.
Is this implemented in RSA? where can it be seen?
Thanks in advance!
Victor
9 REPLIES 9
Message 2 of 10
Artur.Kosakowski
1). You can decide on using the user defined coefficients (which can be set as 1) instead of the code (country specific)  sets as shown on the attached picture.
2) Which point of EC2 is it exactly please?
Artur Kosakowski
Message 3 of 10
in reply to: Artur.Kosakowski
1) thanks!
2)EC-2 5.2.5(b)
Message 4 of 10
Artur.Kosakowski
2). I assume that you refer to the imperfection. Yes, this point of the code is supported and the value is apparently country dependent. The value can be edited in the same way as other coefficients.
Artur Kosakowski
Message 5 of 10
I have two questions:
When I define some user-defined parameters for partial factors, how can I apply it to calculation given that it doesn't appear in the drop down menu? (see images attached)
Can I change "user-defined" to e.g. "HRN EN 1992-1-1"?
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
Message 6 of 10
You can edit the user factors so that the values correspond to HRN EN 1992-1-1 and then set them to be used for selected code (e.g. general EC2). The arrow indicates which set of factors is set as current.
Artur Kosakowski
Message 7 of 10
Ok, I understand this now, but why it isn't shown in drop-down menu? See image attached.
Mirko Jurcevic
Message 8 of 10
Because your current setting is EN code with factors from BS EN instead of these from EN.
If you want to change the code expand the list on the 'code' part of the dialog and change EN to BS EN. By default BS EN will have BS EN factors marked.
Artur Kosakowski
Message 9 of 10
Ok, thanks, everything's clear now!
That "black arrow" is sort of "factors override" for selected code, correct me if I'm wrong.
Mirko Jurcevic
Message 10 of 10
Correct.
Artur Kosakowski
