Hi ,
please i need a help.
I would like model the sub-grade reaction ks =450t/m3. i must define kS in elastic support or in panel thickness or in the both. and if i defined Ks in elastic support and in panel thickness ,the robot will take ks=900 T/m3.
please help me.
Solved by Simau. Go to Solution.
Not both at the same time.
I suggest you to use panel thickness as you'll can get results (displacements, reactions) in maps.
thank you for your answer,
but if i define the sub-grade reaction just in panel thickness i have this message "No supports" .
what can i do?
Thank you.
