hi
How to get the shrinkage deflection in Robot for a specified shrinkage strain.I have modeled an equivalent uniform temperature loads and done a cracked deflection check for the load but the result is not matching with CSI SAFE.In CSI SAFE we can add the shrinkage strain in nonlinear deflection check(See below).
Regards
Pritha
As you mentioned, for shrinkage, you can define shrinkage as separate load case if you want to consider.
Also, you can have a look for this
Deflections-creep and shrinkage in a reinforced concrete slab
Mohammed Ata
Structural Design Engineer
Autodesk Expert Elite
