Hello everyone
i'm trying to install RSA 2017 SP 1 but i got that window in the photo and he require path for installation package "RSA.msi" and i don't understand what path i should use, can any one help me
when i click ok i got that
As you deleted this file after installing RSA 2017 you need to unpack the installation to this location (you don't have to run the installation again).
Hi Artur,
This problem happens on my Robot 2016 when I open the program sometimes.
It's strange, the autodesk documentation suggests that it's OK to delete the contents of the folder after install.
If I click cancel the program runs fine.
Tony
The RSA 2016 installation folder is not needed as long as the folders, files and registry are coherent with their state just after the installation however a change like e.g. change of a user will make them to be incoherent which will result in having this message displayed (when the installation folder has been removed). This is because RSA wants to create a new registry with use of the installation tools which were removed.
This will not happen for RSA 2017 as this part has been changed.
ięty.
Hello everyone
Whenever i try to use RC desing it appears to me this error.
Can you help me please
