Robot Structural Analysis Forum
Welcome to Autodeskā€™s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Overturning moment
17 REPLIES 17
Message 1 of 18
MUHANNAD.ABU_ABDO
2141 Views, 17 Replies
Overturning moment
Hello everybody ... i'm wondered why overturning moment is zero ? when i calculate seismic force on each floor by using equivalent lateral force
Muhannad M.Abu Abdo
Structural Design Engineer
17 REPLIES 17
Message 2 of 18
I think it is because is applied seismic forces and not effort in the structure. Seism induces horizontal forces only (no moment) that induce shear, moment, comp/tract.
Message 3 of 18
So if there's eccentricity causes torsional moment robot will not take it into account !! is there's way can i find the overturning moment from it or should calculate it manually
Muhannad M.Abu Abdo
Tags (1)
Message 4 of 18
see reaction  and effort in the bars after calculaing the model
Message 5 of 18
what do you mean by effort ? i don't understand you perfectly
Muhannad M.Abu Abdo
Message 6 of 18
N, M, V in the bars
Message 7 of 18
But i'm talking about shear wall !! not columns
Muhannad M.Abu Abdo
Message 8 of 18
then look at the effort in your walls ! or post your model.
Message 9 of 18
i found this problem also .. there's big difference between manual calc. and robot calc .. take a look to these two pics
Muhannad M.Abu Abdo
Message 10 of 18
in reply to: MUHANNAD.ABU_ABDO
I know this is quite an old post but I seem to be getting zero moments as well. I'd assume it calculates the overturning moments. How do you get the table to show values and how can I check the equation it uses to calculate it? I'm using RSA 2017.
Message 11 of 18
MUHANNAD.ABU_ABDO
you can get the table from Analysis >> calculation note, and you can check the results if you want as double check by using manual calculation, you have all the required parameters so it's easy to calculate the base shear value manually and compare it with the one you've got from robot analysis
Muhannad M.Abu Abdo
Message 12 of 18
Yes, but my question was not about base shear (I can compare that easily to my hand calculations). I was referring to the bending moment that the output shows as zero. I'd like to know what I should do to make the results output values to the overturning moment which I can use to compare it to my hand calculations.
Message 13 of 18
Refaat
Hi
If you want to study the overturning moment in direction e.g (Global ā€“ Y) then (the moment about X-axis) should be considered (Mx) while as in this case (My = 0).  The values of both of them are mentioned in stories table. (See capture).
 Therefore, I am not sure about the moment (M-- (Not specified)) which is mentioned in the calculation note. (See capture).
  I look forward to hear from one of official technical team to explain this issue.
Regards
Refaat
Message 14 of 18
in reply to: Refaat
Thank you for your contribution refaat,
While that is unusual for RSA to output something vague like that, I also noticed that the shear values you get per storey in the calculation note does not match the ones that you seem to get when you output the tabular loads for storeys (as shown in your image). Only the 4th storey (156.06kN) match up but not the rest. Seems like RSA is unsure what to output as data...
I too would like to hear Autodesk's official response to this.
Message 15 of 18
Refaat
Hi
I would like to draw your attention that the shear values in both 3D graphical model & stories table are represented (cumulative values) whereas the shear values in calculation note are related to each story.
For instance:
V (story 3) = 268.33 ā€“ 156.06 = 112.27 KN
However, for the moment values in calculation note still need some clarification from RSA technical support.
Refaat
Message 16 of 18
Artur.Kosakowski
in reply to: Refaat
Regards
Refaat
They are in-plane ones (in XY plane) = horizontal force calculated for the story * defined eccentricity
Artur Kosakowski
Message 17 of 18
in reply to: Artur.Kosakowski
would you please advise on how to check the overturning moment ?
how to calculate M0 and how to check it if it's ok or not
thank you
Message 18 of 18
The answer given does not make any sense what so ever. My and Mx are by nature in plane. Would you elaborate on your answer and clearly explain how to resolve the stated question.
Furthermore how do you get the overturning moment in the individual panels - which eccentricity must you divide by_
Technology Administrators
