Greetings to all, I am Ivan Flores
I have a problem with RC Design of walls. It tells me that no loads have been
applied to the wall. (I leave here the analytical model of the containment wall
with the applied loads of soils, earthquakes, wind, DL, LL, already calculated ..
When going through the stage of calculation of state of last service and
check the admissible arrows I go to the last module , Which is the real armor
and is when it marks the error.
Note:
I use Robot Structural Analizys 2015 in an Alienware with 8 GB of RAM
with Duo Core processor with 1 GB of memory dedicated to graphics
Solved by Artur.Kosakowski. Go to Solution.
As the main load is acting in the direction perpendicular to the walls you should design them in the RC Slab Reinforcement module instead. Please watch the recording of the 5th Robot webinar where this difference was explained. The recording is available from:
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
