after a crash (not so rare) in the model restored the the loads - mass conversion is always corrupted ....
....and always you get the following message...
Any suggestion ??
The copy of model used when restoring after a crash is very similar to the file used when opening model in repair mode.
The internal structure is simplified and some information is not stored (results, file properties, screen captures, open viewers ...).
Lack of file properties results in the message that the file was created in previous version.
Moreover the information about load cases used in load to mass conversion is not displayed correctly. It is enough to run analysis and this information will be refreshed during model generation.
Best regards,
Setting to zero the case number in the load to mass conversion was fixed in Service Pack 3 for ARSA 2014. Can be downloaded using live update or the link below:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22436870&linkID=13140816
