Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Beam offsets together with releases.
6 REPLIES 6
403 Views, 6 Replies
Hi.
Is there a way to combine a "Beam offset" and a "Release" for an arbitray member without getting error message when executing the analysis?
I am able to use offsets and releases i the same analysis, but not on the same members.
BRGDS
FC
Tags (1)
6 REPLIES 6
Rafal.Gaweda
in reply to: Rafal.Gaweda
Hi
It did not solve the problem, I still get error messages.
I don't know if errors affects the result?
Errors disappears if I chose only to use either realease or offset.
BRGDS
Frans
Rafal.Gaweda
please send us the file
Rafal Gaweda
Please, see enclosed
Rafal.Gaweda
You have to use DSC algorithm and that's why you have to get rid of offsets or replace offsets by rigid links.
Example:
Rafal Gaweda
Ok, so releases requires DSC, but offsets does not work with DSC.
>From what I understand, it is ok to use offsets and releases in the same analysis, but not on the same member.
Brgds
Frans
