Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
wrong rebar volume
6 REPLIES 6
581 Views, 6 Replies
wrong rebar volume
Seems to me Revit Structure 2008 is reporting the wrong estimated
reinforcement volume.
For example:
I draw a 10m long concrete beam (300mmX600mm)
Then add a 19M rebar to it (10m long)
In the beam properties, the estimated reinforcement volume is shown as 0.006
m3
If I pick the rebar, Revit shows it's reinforcement volume as 0.006m3
Shouldn't a 19M rebar (ASTM A615M, which has a 19.1mm diameter and a section
area of 284mm2) by 10m long, have a volume of 0.0028 m3 ??
Cheers,
Jorge
6 REPLIES 6
Joe.Charpentier
It looks like you're right Jorge.
I'm getting roughly double the volume of reinforcement that it should be.
Joe
Thanks Joe,
Yes, looks like a "bug" to me, also present on version 4.
Jorge
wrote in message news:5615173@discussion.autodesk.com...
Joe
Joe.Charpentier
How do you show reinforcement volume for regular bars in RST4?
I know you can schedule area reinforcement by host for walls and slabs...
Joe
Joe.Charpentier
The Revit Structure page has been updated with a new build:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=9281007
Check the release notes- it says that the rebar volume bug is fixed.
Joe
Thanks for info. !!
Saludos, Ing. Jorge Jimenez, SICAD S.A., Costa Rica
wrote in message news:5623782@discussion.autodesk.com...
Joe
Joe, sorry for the confusion.
The bug in RST4 was in the reinforcement volume on walls.
The reported reinforcement volume for a wall is about 10% less than what it
should be.
I'm downloading 2008's latest build to see if both bugs were taken care of.
Saludos, Jorge
wrote in message news:5615509@discussion.autodesk.com...
Joe
