Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Writing Script Routines in Revit?
1 REPLY 1
cposey
3384 Views, 1 Reply
Anyone know if it's possible to duplicate one of our workflow methods in Revit?  Under the AutoCAD platform, we had a script routine with a keyboard shortcut.  Specifically we set it up to initiate a leader, and ask for the note number.  This number referenced a text file with a list of standard notes we like to use detail to detail.  We'd like to create something similar in Revit, without resorting to keynoting.  Keynoting is great, but this is more for non-modeled elements and detail components (i.e. "RAILING, SEE ARCH DWGS").
Thanks.
1 REPLY 1
Joe.Charpentier
in reply to: cposey
It almost certainly be done through the API- you'll need to have some .NET skills (VB or C#).
I'm not a programmer, but I understand there are samples included in the Revit installation.
You can also head over to the Revit API newsgroup for advice:
http://forums.autodesk.com/t5/Autodesk-Revit-API/bd-p/160
Joe
