I kept crashing Revit the other day and when I sent the error report it sent me a service pack download link, I installed it and now every time I open a new file be it family or project, Revit moves my floating Project browser and Properties to the middle of my second screen and on top of each other???
I use my properties and project browser on my second screen and I’d really like them to stay where I put them...
Cheers
Corey
Dear Corey,
I understand that you have problem with the position of the Project Browser of Revit since you have installed the service pack. In Revit there is possibility to reset the user interface to the deafult settings. Please see the exact details about the steps on the following link: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16825244&linkID=9243099
A note:
This technote was written for Revit 2012, but you could apply similar methodic in the case of Revit 2013 as well. (The automatic script cannot run for Revit 2013; if it is about Revit 2013 you need to do the changes manually.)
Hope this way you can fix the issue.
Kind regards,
