Hi
I would use the following formula to calculate the weight of the rebar ,But only the value 0.00 will be displayed
1- w=(d^2)/162
or
2- w=((d^2)*0.617)/100
or
3- w=((d^2)*6169)/10^6
Solved by shadi.razzouk. Go to Solution.
I'm not really sure but based from my experience to calculate the weight of rebar in Revit, the steps are as following:
Finally, to get the total weight of rebar, just multiply the rebar weight per unit with quantity.
It works for me but if anyone have another correct way, kindly share with me.
In the schedule properties, create a new calculated value and use this formula: (bar diameter*bar diameter)
there is another possibility to calculate the total weight and get a bar schedule. You can use the plug-in SOFiSTiK Reinforcement Detailing and get a document with some nice tables and bending schedules.
Kind regards
Björn Teutriene
Yes, I also use Sofistik Detailing to generate automated bar bending schedule.
How to calculat Weight of rebar per shett?
Weight and tot total weight of rebar?
I've tried so showed you on discussion , but does not work.
I hope you can help me this.Regards
Hey Nissar59,
The only way I found is this:
1. Create a Project parameter e.g. Rebar_Sheet and fill it out for every rebar.
2. Use this parameter in your schedule in order to filter only these rebars that are assigned to your desired sheet.
3. Calculate the volume (Schedule: > Edit Fields > Calculate Value... and use the parameters Bar Diameter and Total Bar Length
4. Calculate the weight (Schedule: > Edit Fields > Calculate Value... and use the parameter volume and multiplicate it with the density (there is no parameter for that, just write down a number in the formula.
4. Edit Formatting and click on Calculate totals for your new parameters.
Does it work?
Hello 123qwerfv,
Kind regards
Shadi
