To make it appearcorrect, there are two methods. Since I'm an Arch. I can't speak to how the slab(s) will react with the analysis programs. You can make a single slab, the total thickness, then create an inplace void family, have it cut the slab partway from underneath. This void can be arrayed after you are sure it is cutting the slab correctly. You can also create a thinner slab, and use concrete beams as joists underneath. You can then use the join geometry tool to make a section of them appear correct.
Scott Womack
