Revit Structure
Active Member
caddaccolyte
Message 1 of 13 (679 Views)
View Range - Foundation Plans
679 Views, 12 Replies
12-07-2009 06:49 AM
How do I display elements that are above my cut plane? I have a foundation plan that needs to show foundation walls, wall footings, isolated footings and columns. The top of wall footings are at -2'-8" the top of isolated footings are at -8". The bottom of foundation walls are at -2'-8" the top of foundation walls are at -8". The bottom of the columns are at -8". How do I set my view range so that it shows the foundation walls in section but also shows my columns?
Thank you
JACMD08
Message 2 of 13 (679 Views)
Re: View Range - Foundation Plans
12-07-2009 07:58 AM in reply to: caddaccolyte
at what elevation is your cut plane set?
yo need to set your bottom range at least -3'-0" and your view depth at the same elevation or lower
Active Member
caddaccolyte
Message 3 of 13 (679 Views)
12-07-2009 08:04 AM in reply to: caddaccolyte
That is the essence of my problem. If I set the cut plane at -1'-0" then my foundation wall shows correctly (in section) but my columns don't display. If I set the cut plane at 0'-0" then the columns show but the foundation wall is in projection (no material hatch). Is there a way I can set my cut plane at -1'-0" and show the column graphics from above the cut plane?
thanks
JACMD08
Message 4 of 13 (679 Views)
12-07-2009 11:03 AM in reply to: caddaccolyte
I think your cut plane should be set at +1'-0"
Active Member
caddaccolyte
Message 5 of 13 (679 Views)
12-07-2009 11:22 AM in reply to: caddaccolyte
Ok, thanks. How then do I apply the material hatch to my foundation wall? When the cut plane passes through the wall it will show a cross hatch for masonry and a stippled hatch for concrete. When the cut plane is set at +1'-0" then the foundation wall shows as projection (no hatch).
Active Contributor cae
Active Contributor
cae
Message 6 of 13 (679 Views)
12-08-2009 01:37 AM in reply to: caddaccolyte
please post pictures
Valued Mentor
Ian_Bryant
Message 7 of 13 (679 Views)
12-08-2009 02:42 AM in reply to: caddaccolyte
try the paint comand
Regards Ian
JACMD08
Message 8 of 13 (679 Views)
12-08-2009 06:26 AM in reply to: caddaccolyte
The only thing I can think of is doing a plan region around your wall and changing the cut plane there.
Active Member
caddaccolyte
Message 9 of 13 (679 Views)
12-08-2009 06:33 AM in reply to: caddaccolyte
Here is a screen shot... Does anybody know what the Column Symbolic Offset controls?
This shows the cut plane at -1'-0". The walls show correctly, but the columns above are not displayed.
Active Member
caddaccolyte
Message 10 of 13 (679 Views)
12-08-2009 06:35 AM in reply to: caddaccolyte
Here is an other screen shot... Does anybody know what the Column Symbolic Offset controls?
This shows the cut plane at +1'-0". The columns show correctly but the walls do not.
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
