Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Vertical Chamfer at Wall Joint ?
3 REPLIES 3
RTJMartin
1865 Views, 3 Replies
I have 2 Structural walls (Generic concrete) meeting and need a vertical chamfer on the inside of the joint. Any ideas?
Richard
3 REPLIES 3
Can you sketch something so we have a better idea of what your trying to do?
Ideas to try(In no specific order):
1. Split with Gap
2. Disallow Join
3. In-Place Family (with or without void form)
4. Vertical Wall Reveal (Custom Profile)
michael_fett
RTJMartin
in reply to: RTJMartin
I've tried attaching a PLAN view of what I want to model, but it doesn't seem to want to work for me.
Perhaps I should have said a "Fillet" as opposed to "Chamfer".
AJA14
You could create a vertical wall sweep using the tool or create an in-place family with any shape you want. If your intent is just to fillet the walls, then you can simply use the fillet tool from the modify/walls ribbon. It is located in the draw tools.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
