Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
vertical bracing / True north problem ???
2 REPLIES 2
384 Views, 2 Replies
Hi, i have found an annoying problem / error in revit which i have no idea how to solve, I model vertical bracing the correct way by using a framing elevation then using the bracing tool to model my vertical bracing.
The problem occurs in a plan view, my detail level is set to course and  the vertical bracing shows up has a dash line offset from the grid line which is correct. The problem I get is when I rotate my model from project north to true north (from the manage tab, rotate to true north command)  the vertical bracing goes back on grid line and I want it to be show offset from grid.
please view the attachments to have a better idea what i mean
Has anybody else had this problem and know how to rectify it ?
thanks
2 REPLIES 2
alan.quinn
Unfortunately this a know issue our development team is working on. The only work a round I can think of would be to add another annotation line that does not fall under the Grid. Sorry for any inconvenience that this is causing and thank you for posting.
in reply to: alan.quinn
I'm using Revit 2013 - and Vertical B is misbehaving. I'm not using true/proj north, but I'm using a scope box to rotate my sheet view. The same bahavior. Any workarounds, anyone ? Short of "faking a drafted line ? I HATE to fake things, but it seems I don't have much of a choice in this matter.
