My company standards require 2 lines for the grid bubble (see attach image). The problem is when the grid line is horizontal it flips the text as well... is there a workaround?
Thanks!
Solved by CoreyDaun. Go to Solution.
There are two parameters being referenced here, right? Is there only one label with a break, or are there two separate label entities?
Combine the two into a single label. While editing the label, check the box for "Break" to have Revit automatically put them on two separate lines. I believe that this will make it "behave" more like you want it to.
Did you add the second parameter to the label? You have do that first, so that there is something to place a break between.
