Hello all
I was just wondering if any one has come across this scenerio and needs some clarity of thought.
I have a concrete retaining wall and I am using the extensions to model the rebar but the spacing of the rebar for both horiz and vert have different spacing on each face of the wall.
My question is should the wall be modelled with a common spacing and just notated or is there a way to get revit to model the different spacing.
Thanks in advance.
Kevin
Generate rebars using the extension. Select rebar which spacing you would like to change. Choose appropriate settings in ribbon menu 'Rebar set'. I don't think it's possible to generate different rebars or spacing with same direction on separate wall faces.
If the spacing is different on each face/direction, but the spacing is consistent for each layer, you can also accomplish this by creating an area reinforcement element in the wall.
Joe
