In revit 2013, no family templates. The building design suite ultimate 2013was installed from the authorized Autodesk USB.
In option/file location it says: Default path for family templates files => C:\ProgramData\Autodesk\RVT 2013\Family Templates\English
In this case ProgramData folder does not exist at all in C:
Any suggestion?
Regards
Albi
Solved by scott_d_davis. Go to Solution.
the program data folder is a hidden folder that windows hides
DarrenP
you may have skipped the content installation portion of the install. Go to Add/Remove programs in Control Panel, and run a "repair" of Revit. When the installer re-launches, one of the options will be to install content. Put the USB in before running the "repair"
