I would like to detail in a 3d connection (steel plate and all) of a Beam to a concrete wall. I have the " Steel Connections" extension from Autodesk and it is missing this ability. Is there anyway to create this connection?
Solved by AJA14. Go to Solution.
You could either create a callout, and use detailing to get what you need, or you would create a drafting view and do it as you would in autocad, using 2d drafting. Still waiting on Autodesk to improve this area.
So there is no way to model this connection three dimensionally? Has anyone ran into this situation and found an extension, plugin or work around?
to do it as a 3D model element, you would have to export to ASD or TEKLA, do the connections theri, and import them back to revit. I haven't personally done that, but I know people who have used tekla for this, and I went to an Autodesk seminar and asked this question and his answer was to use ASD (Autocad Structural Detailing).
Thanks AJA14, I tried to use ASD yesterday to create this connection but ran into many problems ( first time using it was most likely the main problem). Do you know if when you import the ASD connection into Revit does it show up as a 3d object or is it a 2d cad file? Also I am assuming it does not have any information that can be attached to the object if so.
Hi. anything you export to ASD or TEKLA will come back in 3D. However, another option would be to buy SDS/2 connect and use it. It is an add-in for revit but it is expensive (1500 dollars). However, it is available for free trial for 30 days. I suggest you install and try it and it may be what you're looking for. Regards.
