Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Type Catalog
6 REPLIES 6
edw
Community Visitor
353 Views, 6 Replies
Type Catalog
I am trying to add base plates and cap plates to the default steel columns in revit structure. I have copied the HSS-section to a server and made changes there. How can i add the catalog to the new family? i.e. load a 4x4 or 3x3 or 5x5 etc.
I have a type catalog for my baseplates, which works fine.
6 REPLIES 6
edw
Community Visitor
in reply to: edw
Got it,
type catalog names must match the new file name and be located in the same directory
in reply to: edw
>>in revit structure..
I don't think that's a good idea.
wrote in message news:5480368@discussion.autodesk.com...
Joe.Charpentier
in reply to: edw
Could you elaborate on why you don't think it's a good idea?
I'm interested in some of the possible problems.
Joe
in reply to: edw
Maybe I'm misreading the original post. It sounds like he is adding
connection parts to a column family. Why? Wouldn't it be better to have a
more robust set of connection families that would attach to stock columns?
Wouldn't columns with attached base and column plates more appropriately be
made as groups?
Arthur
wrote in message news:5511723@discussion.autodesk.com...
Joe
in reply to: edw
Just because it CAN be done doesn't mean it SHOULD be done.
I guess it depends on your business, but in a structural office I don't
think it is beneficial to model every detail of the structure.
Instead, just detail it.
Example, will you also consider the grout space under the plate? What about
anchor bolts? What will you do when the base plate needs to get wider to
accomodate a diagonal brace attaching to the base of column?
Will your theoretical attachment point change when you add the plate? Will
the analytical model remain joined at that point?
I think you can get carried away with the level of modelling and it won't
really be beneficial to the printed output.
Joe
edw
Community Visitor
in reply to: edw
I made extrusions of base plates and cap plates. The catalog imports the column of choice, and i can input type properties for plate dimensions, which show up in my tag. It works well in plan view since i to input plate dimensions for CDs. For architects that import the structure, it helps to see sizes.
