Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Trying to Create "Bent" shear plate for Beam!
2 REPLIES 2
PAULRYMAL7709
1022 Views, 2 Replies
Hi! Having a heck of a time trying to create a simple Shear Plate for beam connections. I am finding that Revit works fine for any elements that are 90 degs to each other, but when you start going on a angle it is very difficult to create & constrain very simple Geometry. I have spent many hours over the last week trying to figure this out. There is absolutely nothing on any webiste I could find on this. I am tempted to give up in trying to sketch anything in Revit & just create in Inventor or Solidworks and import into Revit. I've tried linking to Autocad Structural Detailing but its the same situation anything that is off a straight 90 angle does not seem to meet the criteria for a Structural connection. Trying to load this  connecting plate family into the project & constrain is also a nightmare. Everythng wants to move only at right angles to each other "NO Angled" constraining available. Could someone please advise me or point me in a proper direction so I don't have to spend anymore time on this. My client is going to want these connections shortly! Using Revit Ultimate 2014
Paul Rymal
2 REPLIES 2
awes
in reply to: PAULRYMAL7709
Make a plate based on face based generic model. Insert bolt holes using voids. Insert plate using web as face, use align to fit the plate against the web of the other beam.
PAULRYMAL7709
in reply to: awes
Thanks AWES! Appreciate the time here. However this only touches my issue. It seems like there is nobody here that has a resolution or fix for my problem. I am currently in touch with Autodesk via Taping the problem with the application & Geometry involved. This case can be closed now
Regards
Paul
Rail Community
