Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Transparent Floor
1 REPLY 1
3274 Views, 1 Reply
Transparent Floor
So i'm trying to make it so that my floor isn't transparent so I can see the pipes elevation with reference to the floor bottom, but the floor won't stop being transparent.  I am new to Revit so it's probably just an easy problem, but the help files and previous posts that I've been going through the last hour haven't helped so I figured I'd post it.  The picture shown is a top view where the pipes shouldn't be visible, but are.  I've given the floor a material and set the transparency to 0.  I have changed the view to shaded.  I have tried other materials.  Thanks for your help in advance!
1 REPLY 1
maciejwypych
In view properties, you'll need to change the view discipline to Architectural or Structural.
