Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Transparency settings
2 REPLIES 2
1701 Views, 2 Replies
I'm have a little over 6 months experience in Revit and I'm having problem with the transparency settings. I've created a generic model that I want to use to simulate water.
In order to see the topography I've created located "underwater" I make the generic model a level 50 transparent.
The image above shows my problem, it is like the other models become transparent as well. I would like the "water" to remain behind the dam.
Any advice would be much appreciated.
Thank you in advance
hms
2 REPLIES 2
Lance.Coffey
If you are using the 2013 software, it looks like you are seeing the issue described in the following blog posting:
Glazing Appears Through Walls in Revit 2013
http://revitclinic.typepad.com/my_weblog/2012/04/glazing-appears-through-walls-in-revit-2013.html
Note: The issue relates to transparent elements (not just glazing).
Lance Coffey
Technical Support Specialist
in reply to: Lance.Coffey
Thank you for your reply. This proved to be much less of a problem than I thought. Once I printed the model (pdf and on paper) the picture came out just right, with no transparency in the dam. It only looked like that in the Revit model window.
