Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
transferring rebar to new slab
1 REPLY 1
kevms
441 Views, 1 Reply
Hello All
In my current project, i have modelled the rebar for both the upper and lower layers. the architect has decided to change the slab profile meaning there are areas that have become larger and others removed. I wanted to copy the new slabs from the arch model but i really don't want to remodel the rebar. Is there a way to transfer the area and path reinf to the new slabs.
Thanks in advance.
Kevin
Kevin
Using Revit Structure 2012, 2013, 2014
I think I am getting the hang of this revit stuff
1 REPLY 1
awes
in reply to: kevms
Select all rebars, make a group, delete slab, insert new slab, explode rebar group, adjust rebars.
