Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Toposurface; relative elevation problem
0 REPLIES 0
Message 1 of 1
BananApan
495 Views, 0 Replies
Hi, Im using the toposurface tool in Revit structure 2014, up to date version.
I've set elevation for both survey and project base point to 0.0
When I then draw the toposurface the elevation in the ribbon is set to 0.0: Absolute Elevation, the problem is that the toposurface is placed 105 meters above my project base point.
Using the spot elevation tool the relative elevation on the toposurface is 0, the project base and survey points are 105.23 meters.
Is there anyway I can change the relative elevation to 0.0 as well? So all three of the elevations are set to 0.0.
0 REPLIES 0
Rail Community
