Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Timber beams not displaying correctly at supports
9 REPLIES 9
Message 1 of 10
DaveDrahn
878 Views, 9 Replies
This has to have been asked before but I don't find anything here or in help.  Simple timber beams over timber columns show the support reaction point at the center of the column, but in medium or fine display mode the beam shows cut back to the edge of the column even though it clearly rests on top.
I've looked at Manage -> Structural Settings -> Symbolic Representation Cutback and that's not it.
Any other ideas?
Thanks.
9 REPLIES 9
Message 2 of 10
dkwolek
in reply to: DaveDrahn
Hi
If you could send Revit sample file it will be very helpful.
Thank you
Dariusz Kwolek
Structural Product Manager
AEC Solutions
Message 3 of 10
DaveDrahn
in reply to: dkwolek
Sure. It's 8M. Where should I send it?
Message 4 of 10
dkwolek
Just add as an attachment
Dariusz Kwolek
AEC Solutions
Message 5 of 10
subhra_civil
Please upload your Revit file here so that i can understand exactly what is the problem.
Thanks & regards,
Subhradeep Sen
Kolkata
India
Message 6 of 10
DaveDrahn
5M maximum file size...
Message 7 of 10
dkwolek
Hi
The question is what do you want to achieve?
Do you expect the longer beam sits on top of columns and shorter beam should adjust to the longer beam or something else ?
P.S. if you make column a bit longer (e.g. by changing Top offset value) – both beams will be joined with column as shown on below picture.
Dariusz Kwolek
AEC Solutions
Message 8 of 10
DaveDrahn
Let's say we remove either one of those beams. I'd like the beam to sit on top of the column. I see this happen pretty regularly and thought I was just missing a display setting somewhere.
In this case, I was wanting to get the deeper beam to sit on top of the column and the use a Simpson type connection from the shallower beam to the deeper.
Message 9 of 10
Rafal.Gaweda
I think you are looking for this behavior :
Rafal Gaweda
Message 10 of 10
DaveDrahn
in reply to: Rafal.Gaweda
Yes, Wow. Disallow join.  Thank you!
