I was wondering why I can't tile my windows when I have a schedule along with plans/sections open as well. If the active window is NOT a schedule, I can tile, but not if the schedule is active.
Thanks for any input.
Solved by haydenwse. Go to Solution.
Schedules will tile but you need to be in a view to get it to work. Open the schedule, then activate the view and click "window tile". It is really handy and I use it all the time.
You're probably referring to the Keyboard Shortcut "WT".
In general, keyboard shortcuts will not work when you are in a schedule view, as most of the time you will be editing text.
However, you can still activate the "Window Tile" command from the ribbon:
"View" Tab>"Window" Panel>"Tile" Button (off to the right)
Joe
