Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
tiling windows when one is a schedule
3 REPLIES 3
mcphaill2
606 Views, 3 Replies
I was wondering why I can't tile my windows when I have a schedule along with plans/sections open as well. If the active window is NOT a schedule, I can tile, but not if the schedule is active.
Thanks for any input.
3 REPLIES 3
haydenwse
in reply to: mcphaill2
Schedules will tile but you need to be in a view to get it to work.  Open the schedule, then activate the view and click "window tile".  It is really handy and I use it all the time.
mcphaill2
It is good to know that a view has to be active for the tiling command to work.
Thanks so much!
Joe.Charpentier
You're probably referring to the Keyboard Shortcut "WT".
In general, keyboard shortcuts will not work when you are in a schedule view, as most of the time you will be editing text.
However, you can still activate the "Window Tile" command from the ribbon:
"View" Tab>"Window" Panel>"Tile" Button (off to the right)
Joe
Rail Community
